VR6 from Caterpillar
does somebody got a connetions drawing from this regulator used on catterpillar generator.,. or some info tech about it
I´m looking one
RE: VR6 from Caterpillar
  thank, I try to find it.. but i couldn´t
  do you know some adress to see the manual of this card... cause I´ll like to know more about it, thank in advantage and have a nice new year.
You'll probably need to ring Cat. Any internal schematic of the control circuit is likely to be proprietary, so don't count on getting a circuit drawing. If you look closely at the module you'll see it is potted in resin. That is partly to help minimise vibration problems, but primarily to prevent you repairing it instead of buying a new one. What information are you looking for?
  Sometimes I only open my mouth to swap feet...
not thinking on repair, only to connect it, cause I read in the document that is other manual with additional connections.
thank and sorry for big delay on reply
