Extending Existing Footing
Hi all
we had a project under construction, after casting of some isolated footing we found that the footings does not meet the required length and width dimensions, so we took decision to increase footing dimension around 50 cm to 30 cm from each side,
Existing footings were constructed that it has only bottom bars in both directions (U shaped bars) footing thickness is 400 mm so we decided that the side cover will be removed and then the vertical side of U bars will be straight then new concrete will be casted using suitable additive materials for connection between old and new surface.
1- Is it ok to have a footing without bottom bars not bent vertically at the end?
2-should I use dowels between the two surfaces of concrete or chemical materials is enough?
3- Should I use dowels if I need to increase footing thickness?
RE: Extending Existing Footing
2) I wouldn't trust chemical bonding agents to do anything. Use epoxied dowels.
3) I'm not sure I understand in what direction you want to thicken the footing (I assume at the top), but using dowels is the best method to assure the concrete acts monolithically.
