Weight in ansys
Weight in ansys
Is what I ask so complicated? I only want to simulate the weight of an object placed on a table. What type of load is it necessary to use?
Thank you very much. Regards and merry christmas.
RE: Weight in ansys
RE: Weight in ansys
You should do a static analysis with a load of gravity. Before solution,be sure that you have input the density of the material.
Good luck!
Rock
RE: Weight in ansys
RE: Weight in ansys
I want to measure the spectrum of the vibration of a machine. Later I want to place antivibratory elements (like rubber) to isolate of the support using Ansys. In fact, the system is made of two bracket support (like are used in air conditioning), one shelf and a vibrating motor. My intention is to do the study physically and later to simulate it with Ansys.For this reason, the frequency and dynamic considerations influence in the system.
