Engine Room Ventilation
What are the requirements in Engine room ventilation? Thanks.
RE: Engine Room Ventilation
You can get all this from the engine maker.
As others have mentioned get the combustion air requirement, the heat off of the block, the heat off of the alternator and the heat picked up through insulated exhaust to determine your air flow.
If it is a gen with a rad and a cowling outside for the exhaust, the air moving for the rad is going to be limited to 0.5" static per NFPA110, ht
Besides combustion and the rad air, you will most likely need some more air flowing.
Try some of the pointers here http://www
Kohlerpower will have some info as well scroll around on their site
Take the "V" out of HVAC and you are left with a HAC(k) job.
Check out Baldor engines catalogue, google it out. They have good design info, including summary of NFPA 110.
