Steel Wire Manufacturing: Difference between RHQ and CHQ?
Can someone please briefly state the manufacturing differences between recessed heading quality and cold heading quality steel wire?
What are the advantages of one over another?
My product: we purchase 1008 fine grain alum killed wire, we permit for SAFS or SAIP. One company provides the material in RHQ and another provides in CHQ. Each supplier claims thier wire is better, but they do not provide details to back it up.
thanks,
Ron
thanks,
Ron
RE: Steel Wire Manufacturing: Difference between RHQ and CHQ?
Recessed Head Wire is employed when screw heads incorporate a recess configuration such as a crossed or
square recess. This wire involves more exacting precautions and controls than Cold Heading wire, such as improved surface quality and special wire processing. Exacting precautions and controls are necessary in the selection and internal soundness of the steel and in the preparation of billets for surface quality.
Special attention to rod rolling and to inspection of the rods is essential. In order to provide wire that will be soft enough to withstand the very severe cold forming operations, wire for all types of recess head screws is generally spheroidize annealed in process or spheroidize annealed at finished size, with the final drawing incorporated into the heading operation by drawing in process in tandem with that operation. When spheroidize annealed at finish size wire is so employed, the fastener producer should ensure that the final reduction is not
excessive.
