Spray-Fireproofing on Galvanized Structural Steel
I am trying to determine if hot-dip galvanizing has any affect on the adhesion and quality of sprayed-on fireproofing. I've looked at the usual resources (galvanizeit.org etc) and haven't come up with anything definitative. Thanks in advance for the help.
RE: Spray-Fireproofing on Galvanized Structural Steel
Dik
Approved ICC-ES SFRMs are found in the link below
http
Check Grace's Monokote MK-6 series
http://ww
An added level of assurance is the requirement for determination of cohesive/adhesive bond in the field by the SI...IBC Sec 1704.11.5
