SR319-T51 Specifications
I'm trying to track down any information about SR319-T51. Any information would be appreciated.
RE: SR319-T51 Specifications
Could you supply more information about the designation? 319-T51 would refer to a permanent mold 319 alloy casting that is artificially aged (i.e. no solution treatment). But the SR prefix is one that is not known to me.
Thanks Swall! You're correct in that it is a permanent mold Aluminum casting. The SR prefix is something I could find only in a brochure of Harmony Castings. www.harmonycastings.com/techdoc.pdf is the link where you can find reference to this. Hope this helps.
The "SR" could indicate a strontium modified casting. Addition of small amounts of strontium causes the hypoeutectic silicon particles to become much finer than in a non-modified casting and this will increase mechanical properties somewhat.
