Plotting 2 C size drawings on same page
I need help. I am trying to plot 2 C size drawings on an HP DesignJet 750C. The physical paper is on a 36" roll. I am using AutoCad 2000. Any help would be greatly appreciated.
RE: Plotting 2 C size drawings on same page
Open a new drawing,
connect several drawings to it as XREF,
Rotate and move them as you like,
Then Plot.
sc
I am using an HP DesignJet 750C if this helps.
and insert the 2nd drawing next to the
1st drawing and plot them together.
i.e. two Cs make a D sheet. You might
have to play with landscape or portrait
in the setup. Keep us all posted. You
will have to trim it by hand. Bid deal.
