Fuel Gas Knockout Pot
I'm doin an Engineering Work Order, and I'm replacing a Fuel Knockout Pot. Can somebody recommend a manufacturer for a Fuel Gas Knockout Pot.
RE: Fuel Gas Knockout Pot
Before you order, you need to know what to do if the fuel KO drum gets liquids in it.  Does it have a level controller or sight gauge?  Does it have a switch?  Some fuel KO have a ball float system where there is a ball in a cage attached to the outlet nozzel on the top of the KO.  If liquids enter the ball floats up and shuts off the fuel.  A lot of time the KO has a filter in it to remove even the smallest droplets or fine particles of rust, dirt and oils.
There are several shops that can help.  Here is a nice one that will assist in the engineering too.
 http://www.perry-equipment.co.uk/english/products5.shtml
