Thread T.I.R problem
O.K. here goes, try to bear with me...
Machining a 1.25 x 16 LH internal thread. Using a LH threading bar (right to left), part has been faced, bored and a dia. turned on o.d. in one chucking. Other end of part has 3 bearing dia's (+/- .0003). After part is threaded it is mounted on a threaded arbor (machined in spindle with ZERO runout). For inspection, part is thread onto a machined fixture for TIR check (.001 tolerance). Checking fixture machined in One chucking to assure runout, etc.). Consistantly getting .003-.006 TIR. Part is checked while still mounted on machining arbor and checks DEAD Zero!
Have tried turning "stem end" first and colleting on this and threading last and same results. I'm running out of Hair to pull out. HELP
RE: Thread T.I.R problem
I.e., it sounds like the checking fixture thread is a little smaller than the arbor thread.
Mike Halloran
Pembroke Pines, FL, USA
Just going by discription and my invision, I see that there will be a problem checking a part by screwing it on a threaded rod. I would think a straight shaft with a tight slide fit to the part's I (with bearing fits), could be used for verifing concentric machining acceptance
When part is mounted (screwed) onto checking fixture and machining arbor it "snaps" into place, good square contact, Prussian blue shows a clean 100% "seat".
(still just my gut feeling is that part may snug up on the fixture off center with out pilot bores)
