Received DXF files from from NX3, translation to WF2 flakey
Hi gang, I have a customer that has sent me a DXF file from UG NX3. The contents of the DXF is there drawing formats. When I translate the DXF into WF2 the wire frame looks ok but the text in some areas are good, but in other areas the texts repeats itself - no more than doubles itself. The GD&T, I expected it to weird out. Can anyone direct me to improve translation on WF2 side or what I need to tell the UG NX3 person what to select or make in there setting file.
Thanks in advance - Texaspete
RE: Received DXF files from from NX3, translation to WF2 flakey
