Viewport freeze
Viewport freeze
I have a layer I would like to thaw in a drawing which is frozen in model space. I would like however only to have that layer active in one particular viewport (not all of the other 30 in the drawing).
Is there a routine/method which enables us to globally freeze a layer in all existing viewports?
Cheers. Sean.
RE: Viewport freeze
Could freeze it in all viewports then thaw it in the one you want?
"Everybody is ignorant, only on different subjects." — Will Rogers
RE: Viewport freeze
Mind you its a good suggestion - any other ideas?
Cheers. Sean.
