Durability Loads on Watts Linkage
Hi guys,
Sorry if this is already posted, I could find the exact answer.
My question is when you do the durability testing on Watts Linkage what kind of loads are generally applied. I was thinking only radial load should be involved or you need to apply axial load as well?
Any input will be helpful
Dipak
Dipak
RE: Durability Loads on Watts Linkage
Cheers
Greg Locock
Load will be applied on the sleeve and plastic busing.
