appearance.dmt
appearance.dmt
appearance.dmt
I am having trouble getting my appearance.dmt (color palette) loaded automatically into WF2.0
I have the appearance.dmt file located in the "TEXT" subdirectory of the WF2.0 install directory.
I have the path specified in the config.pro "pro_colormap_path" parameter, yet it fails to load automatically.  The rest of my config file functions properly.  I am able to load manually without any problems from the VIEW->COLOR AND APPEARANCE PULLDOWN.
Any suggestions what I'm doing wrong?
Thank you
RE: appearance.dmt
I just realized I have another color/config.pro issue and I'm wondering if they're related.
I have adjusted the offset_line_col parameter to 100 100 0 for yellow offset lines.  They're still appearing default blue.
Is my syntax correct?
Thanks again.
