Defining Multi load-steps
Hi all,
I asked this question before but i could not succeeded to define different load steps. Whenever i do the first load step run, then i define a second load, for instance, then i arrange the "time at the end of load step" in the "solution controls" menu to the desired value and then i run again pressing "Solve current LS" option under the Solutions>Solve menu. But it starts from the very begining.
I mean assume that i gave a ramp increasing displacement of 2 units for 2 secs and solve it. Then i do the procedure mentioned above, set the time at the end of load step to 3 and keep the displacement value 2 units and solve it, it actually solves from time@start=zero, displacement@start=zero and 2 unit ramp displacement for 3 secs.
What do i do wrong?
Can
RE: Defining Multi load-steps
it seems you aren't performing a RESTART but a new solution each time. In fact, in order to use the multi-frame restart capability of Ansys, you have to:
- set the results saving at least for the steps you want (if not the substeps)
- after a solve command, before touching anything in the boundary conditions, you have to go to Solution -> Restart, choose the frame from which to restart (among the availables - see above) and only then you can modify something (including stepped/ramped options). Otherwise, in the very moment you give "Restart", the BC and options operating in the original frameset will be loaded, overwriting your modifications.
Hope I haven't been too confuse...
Thank you cbrn. Your answer is quite useful and i appriciate you. It works now:)
your welcome, I'm glad it was helpful!
Regards!
