Help Header Config
Help Header Config
I just want to asking about my car header configuration :
KIA Sportage 4 cycl 2000 cc DOHC, Torque peak powerin 4000 rpm, HP peak power in 5500 rpm.
my car already use cone filter Yakuza, fuel pressure regulator, ECU remapping, also MSD PN6211 Dis 2.
What is the best config for my car 4-2-1 or 4-1 and what is the positif and negatif each configuration...
NB : my car machine almost the same aspek with mazda mx6
thank
If 4-1 the best can you tell me the pipe size and length for the primary and the collector size and length and the last pipe (1) size and length until muffler.
Also for 4-2-1 the primary pipe size and length (4) and secondary pipe (2) size and length also the last (1) size and length until muffler
Regardsm
thank
Regardsm
RE: Help Header Config
P S I Racing Inc.
407-241-2480
866-PSI-RCNG(toll free)
88 MX6 GT/ FE3
They know everything about the FE3 Mazda motor in your Sportage. This is the 16v 2.0 in the Mazda F series of motors....the American 88-92 MX6 had the F2 and F2turbo...which were 12v / 2.2. Euro and Japanese MX6 got the FE3 but with stronger internals than the KIA verison and of course a different cam that isnt truck biased
P S I Racing Inc.
407-241-2480
88 MX6 GT/ FE3
i'm far away ...
thanks
John@PSI Racing
thanks.
4-1. as far as length, just make sure they are all the same length, you dont want two cylinders of exhaust entering the colector at the same time. plus and even more important than anything you still will have that restrictive cat, so in my opinion go and get a REAL high flow cat from random technology or another real company replace your oem cat first. that is if it is broken/malfunctioning, because it is illegal to replace a functioning cat. just my two sents from a laymen.
