Toolbox hardware mating
Hi all,
Inserting washers into an asssembly via drag and drop on the corresponding hole seems to generally work, adding the appropriate concentric/coincident mate. I cant do the same with screws(usually cap screws). I get a "The document "Socket head cap screw" is already opened, Do you want to show this alreadyy opened document?" message.
Yes drop the srew in space unmated, no ges=ts me "drag and drop failed". We are on SW2005 sp5.0 with network accessible toolbox. Any thoughts? Thanks
RE: Toolbox hardware mating
Our toolbox is on a network server. In the C:\Program Files\SolidWorks 2006\Toolbox\toolbox.ini file, the ToolboxPartFolder entry was set to the full path of the network, i.e. \\serverName\shareName\...
In Windows Explorer, I mapped that \\serverName\shareName to a drive letter and updated the path within toolbox.ini to use that drive letter.
If you give that a try, please let me know if it fixes things.
Eric
I think we have the .ini file mapped correctly. Ive attached it below.
[Toolbox environment configuration file]
Creation=1/12/2006 at 17:38:52
[configuration]
ToolboxPartFolder=U:\Solidworks\Solidworks Data\
Is this similar?
That looks like what I was suggesting changing to. This is vaguely similar to thread559-169356. In both cases it seems like a file is getting stuck open.
Eric
Cole M
CSWP, CSWST, CSWI
All settings are correct. I dont see the browser.mdb file however. It should be in the /Solidworks/Solidworks Data/Part Lib folder?
Cole M
CSWP, CSWST, CSWI, CPDM
The browser.mdb file is set correctly, but alas still no smart mating of components
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I went in and re checked the Read Only option for the Toolbox file folders and it appears to have fixed the problem. Life is good again.
Jumped the gun a bit.
The "fix" worked initially. Changing to a different size screw of the same type caused the "problem" to re appear. Inserting a new type screw seems to work fine. All files are set to read only?
