MSG thickness of Cable Trays
I have a project in which galvanized steel cable trays are rated in MSG. I did some research and i found that 12 MSG = 0.1 inch = 2.6 mm. Usually cable trays are either 1 or 1.5 mm thick. I would like to ask you if this is reasonable? the cable trays are normally loaded, nothing too heavy.
