Outdoor storage of highly corrosive equipment
Searching for ideas as to the best method of indefinite, outdoor storage of high priced, corrosive equipment.
Will need a container which is air tight and can be pressurized (low pressure), ability to check on humidity inside the container and will stand up to the outdoor weather elements.
RE: Outdoor storage of highly corrosive equipment
What will be contained? Temperature variation?
In general, metals will need corrosion protection, while polymers will nedd ultraviolet radiation protection.
Cory
There's a big difference between the two.
We need to store this equipment outside and I was searching for ideas as to the best type of storage container or to see what other people have used.
We are looking to utilize a container which is rather simple to construct around the equipment to be stored but will hold up to the weather and will be airtight and pressurized to a lower pressure inside the storage container.
Mike Halloran
Pembroke Pines, FL, USA
Is this steel? Composites of different metals?
If for example this were a stamping die you could immerse it in a penetrating rust preventative, then a thicker oil, then coat it liberally with grease, then wrap it in saran wrap, then put a heat seal pouch, then a nitrogen pressurized heat seal pouch....
Lots of work.
How about renting a storage garage nearby, or a POD?
This brings to mind a piece in Battlefield Earth where the humans find weapons, and vehicles that were stored in the mountain.
VPI inhibitor.
Here is one, Molykote Metal Protector Plus, that I've used with great success in some tough environments
http:/
Cosmoline
http://www.schafco.com/cosmoline.asp
Give these people a call.
http://www.cortecvci.com/Products/products.php
It has a very low viscosity and penetrates well. It also will not leave the parts oily. Its creates a very thin film. (What I was refering to as a penetrating rust preventative.) But I doubt that its better than a cosmoline over long term.
http://www.birchwoodcasey.com/rust/index.html
Hope it helps
Luis Marques
Thank you.
REGARDS
Luis Marques
I would appreciate it if you could forward any web links for suppliers of the inflatable type of warehouse which you mentioned.
http://www.esidome.com/index.htm
SOME MORE SITES OF INFLATABLE HOUSES
http://66.39.116.220/IT/emergency/
ht
http:
