Clamp shoes shall be used for thin wall pipe
Client spec. requires Clamp shoes shall be used for thin wall pipe.
I am curious about :
1. Thin wall pipe means D/t>100 ? t is calculated excluding all the allowances?
2. What is the the physics requiring clamp with thin wall ?
Thanks in advance
Thanks in advance
RE: Clamp shoes shall be used for thin wall pipe
Apparently they do not want possibly concentrated stresses transmitted from supports directly into the pipe wall.
Some codes (pipeline) where thinner pipe wall thickness are common, do not allow welding of any shoes or supports directly to the pipe.
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
