Smart pigging through check valve
Hi guys
Smart pigging through a check valve tends to affect the functioning of the sensors on the tool. Is there any check valves out there made suitable for smart pigs? From my limited knowledge API6D check valves could be used in normal piggable lines. Do we have any other option?
thnks
thnks
RE: Smart pigging through check valve
Use full opening swing checks, maybe with a rubber coated disc!
launcher no check mainline
^ check
Mainline with bypassed check, for forward or reverse pigging, or if you don't like pigging through in check direction.
bypass check
---------+---XOX--+--------->
(sometimes this arrangement is also beneficial for surge pressures, for instance if the block was an automatic shut-down type)
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
