Parallel leaf front suspension
I am looking for tech. info on the geometry of parallel leaf front suspension but have not been able to find anything in depth on the internet. Can anyone recommend a good book on the subject, (that is still in print!)?
Thanks for any help.
RE: Parallel leaf front suspension
Really the same rules apply as with rear suspensions, although I notice an interesting diversity of opinion about which end the shackle should go. FWIW I think behind the axle would be better for a front suspension.
Are you going to use a 3 link approximation or a non linear FEA model?
Do you have the SAE leaf spring design manual?
Cheers
Greg Locock
thanks for the reply. I agree the shackles should be on the rear. I could not think of any advantage for forward shackles so I be interested in hearing that theory.
As to your second question I have no idea. Hence my need for a book. I am trying to copy the set ups the early cars used with a solid I-Beam front axle, hopefully it is relatively straightforward, I don't want to go back to college. I am using the same set up on the rear.
No I do not have a manual - Posies will solve that problem for me.
Thanks again for any help.
The system is certainly still alive and well in the trucking industry. Perhaps the information you seek can be found there. I have yet to see shackles in the front on any big trucks. Jeep has certainly proven that front shackles work, but they haven't convinced many others to follow.
Cheers
Greg Locock
and the title of the book by Milliken is ...?
Cheers
Greg Locock
https
Norm
Cheers
Greg Locock
Re: RCVD, I guess that would put one in the position of applying the basics behind the text that was read rather than just the text itself - and right from the get-go.
Norm
Cheers
Greg Locock
I am not sure Millikens book is what I was looking for. Isn't it more of a theoretical book? I was hoping to find more of a workshop book rather than a classroom book. I will get the SAE design manual though so it will at least look like I know what I am talking about when I order them.
By the way, Google is not broke, I just enjoy talking to you guys more!
