50 or 60 Cycle power in China
My company is considering sending some equipment we have to a plant in Mainland China. One of the units is a 1500 HP, 4160 volt compressor. I am conserned that if there power is only 50 cycles then this unit will not be able to operate efficiently if at all. Can anyone tell me what power they have. Thanks. bobegler
RE: 50 or 60 Cycle power in China
You can probably get a motor locally.
6.3 kV 3-phase, 415 volt 3-phase, 230 volts 1-phase.
Frequency is 50 Hz. If your equipment is using low voltage AC control power, it is typically 230 volts 2-wire, with the neutral side grounded (similar to the 120 VAC power in the U.S.). They typically do not use any 120 volt AC power.
