Need a source to grind Tungsten Carbide. Parts are Alum/Tung assy.
I need a source to grind a Tungsten Carbide tip, with a .15'' spherical radius, on an small aluminum valve. The initial qty will be low (25-50) but will increase after customer approval. Thanks for any info provided.
RE: Need a source to grind Tungsten Carbide. Parts are Alum/Tung assy.
Try the Industrial Tool Sharpening group on yahoo.
htt
If that doesn't work out contact us. We supply hundreds of shops that grind carbide.
Tom
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
