Capacitor Replacement
Please bear with me - this is not my field....
Last year we had an electronically controlled proportional valve fail (on an injection moulding machine) - replacement cost 1700GBP. The mechanical part of the valve is fine.
Yesterday the engineer from the company gave me a service fix sheet which involved changing a failed electrolytic capacitor (0.2 GBP I guess!).
The question is, is there a "better" type of capacitor one can use? (e.g. more reliable!!) The current one is 47mfd, 50V, aluminium can type, both wires out of one end.
Cheers
Harry
RE: Capacitor Replacement
A better grade of capacitor may not clear the problem, if it is caused by a design limitation. If this was the only faulty part, one thing you can do is to note exactly the brand and part number of the cap. Buy a spare one, and have a local techie replace it if your valve fails again the same way, before calling the repair guy.
A) Replace it with a 105C rated part. Most are rated for 85C.
B) Install one rated for a higher voltage (63 or 100 volts). The higher voltage part may have a greater lead-spacing between the two leads.
However, the real issues are:
1) Why did it fail in the first place?
2) Does the fix sheet really convey the correct and full information of what went wrong?
Electrolytics primarily fail due to heat and overvoltage/transients. Heat can come from the ambient environment, or from large ripple currents internally heating the capacitor. Transients come from voltage surges, lighting, etc.
There was a rash of failing electrolytic capacitors made in Taiwan and China about 5 years ago due to several companies incorrectly copying a proprietary electrolytic formula of another company. They would fail after about a year, and this affected a lot of PC mother boards. But, this involved only a small part of the electrolytic market.
felixc: The 1700GBP was just for the valve - changed that myself - one plug and 4 bolts! 5 minutes!
Comcokid: I see the guilty cap is 150C (well, it's got 150 printed on it)
Your comment re Asian copies might have it - the machine was 4 years old last year when it failed and the fix sheets do not mention other types to go in. (It's also a different colour to some of the other ones on the board..) Also, we have another machine with the same valve on it which is about 18 months older than the failure and no problems - curiouser and curiouser said Alice......
Will just change for now with replacement from reputable source and try it (might of course be something different!)
btw, valve made by Bosch
Cheers
Harry
Sometimes I only open my mouth to swap feet...
Scotty: apologies - serious typo - is 105 on it.
Cheers
Harry
Moral is...Don't expect a pipe manufacturer to know electronics or an electronics sub contractor to care after the design is out the door.
By the way - the normal aging mode of electrolytics in constant use is to slowly lose capacitance over time and temperature as the electrolytic slowly dries out.
Hi all,
Many thanks for the help.
I did bring the camera to work and took a photo - then realised I had left the USB cable at home - Doh!
Will get it on tonight for you to have a look at - it's mounted next to what looks like a transformer - possibly a pule transformer as it appears to have a ferrite core (two E shaped bits?) I really am guessing here......
No swelling or anything though...
Cheers
Harry
Here it is: http://tinypic.com/view/?pic=43xwvtu
The suspect is the one on the right, nearest the bottom of the picture of the group of 5 ...
If anyone in the UK can recommend a "fixer" or can volunteer, would appreciate a call on Prudhoe 836938
Cheers
Harry
Keith Cress
If it is urgent, Dowding & Mills have an excellent repair facility based out of Leeds who will collect & deliver your item back to you in a working state. Costs a little more but for those "Right Now!" jobs they can be useful. Also pretty good on PLCs and drives. Not sure what they are working over Christmas.
If it was to find its way down to Teesside Power Station in the New Year I'm willing to have a look at it for you and get the cap swapped. Testing it might be a bit trickier - no circuit diagram and so on - depends what the demise of the capacitor caused as collateral damage. There looks to be plenty of board space so putting in a cap with a better spec should be feasible. The item next to it looks like a high frequency transformer, so ripple current might be the problem. What brand are the capacitors? Sometimes the giveaway about quality is that no one outside of China has ever heard of them!
Is the splodge of blackish crud on the bottom right corner near the grey edge strip significant or is it some innocuous mark?
A bass player friend just asked me to work on his Ampeg amp. This is a recent design with tubes and FETs. They took two electrolytics and tightly sandwitched them between two hot running 10 watt resistors. Another is right up against the base of a tube. Plenty of space to put them somewhere else.
