Deactivate with error.
Hello every body:
Is there any way to deactivate a curve when it is in error, For example when  I do an offset of a circle to the inner side wtih an offset value biger than the radious. Could it be done using , rules, reactions, loops???.
Thank you.
RE: Deactivate with error.
Each method would work.  Do you have a KWA (Knowledge advisor) build license?
Derek
yes I have KWA.
I have realized that the error curves are "Unresolved" curves. And in rule editor of r16,I can see that in the "language browser" there is an attribute of a curve called "error". How can I extract these attribute to a parameter??
