Miniature pressure vessels supplier
Dear members
I am looking for a company who can supply miniature pressure vessel (cylinder). Does any know of such company? By Miniature I mean around the 300 to 600 ml volume and pressures of up to 16 bar.
Thank you
Thank you
RE: Miniature pressure vessels supplier
Mike Halloran
Pembroke Pines, FL, USA
http://www.hydrospin.com/product_info/index.html
http://www.parker.com/icd/cat/english/4160-SC.pdf
ht
Maybe look under the "UM" stampholders
Try Flowguard Ltd in the UK (+44 1663 745976)
A.
In a pinch I've used Pall or Milipore filter housings for quick R & D runs.
for Code or Non-Code miniature vessels
I have been in similar situations and I simply had a shop fabricate a vessel out of a piece of pipe with some pipe caps. Given the small size and low pressure I did not even require them to stamp it as a pressure vessel...which cut the cost. Having it fabbed in a shop also allowed me to add the end connections I wanted."
I've did the same as ggrindle, I fabricate it myself by using a XXS pipe and caps (50 bar, 15" long x 4" diameter) and they were used as a sealing pot for instruments tubing.
Luiz
