Can I sit for the FE and later the PE? Florida.
I have a BS in Physics and am enrolled in a masters in civil engineering currently. The masters program is not abet accredited (because abet will not accredit both a bachelors and masters program from the same university?). Will i be able to sit for the exam w/out the accredited bachelors??
RE: Can I sit for the FE and later the PE? Florida.
You can always just email/call them and ask.
If a PE is your goal, sounds like you are wasting your time and money at your current school. If you're like most of us, you have plenty of time and money to burn, though.
In any event, the state board is the one that would make the call. Email or call them as mentioned above and see what you can find out. Usually, the state rules are online somewhere, and you can peruse them in detail as well.
http://www.fbpe.org/
and basically ask for persmission to sit for the exam. There was some sort of multiple choice test based upon the statutes, and then you would get a response allowing you to be listed for the test. Beyond that you had to register and pay for your seat. I think that website is the place to ask, although it can be a bit tricky to navigate.
