Passing a UDT to a procedure -"Expected array" error
I obviously don't know enough about passing variables to procedures and am having a difficult time with passing an array.  I have defined a user type named "transforms" in a module as follows,
Type transforms
    tx As Double
    ty As Double
    tz As Double
    rx As Double
    ry As Double
    rz As Double
End Type
and,
Declared transform as transforms, also in the module.
In main code I define the values of the first transformation and attempt to pass them to the transform)xyz procedure like so,
  transform.tx = Val(Text1(0).Text)
  transform.ty = Val(Text1(1).Text)
  transform.tz = Val(Text1(2).Text)
  transform.rx = Val(Text2(0).Text)
  transform.ry = Val(Text2(1).Text)
  transform.rz = Val(Text2(2).Text)
  pt = 1
  transform_xyz pt, transform()
to a public sub,
Public Sub transform_xyz(pt, xyz)
I get an "Expected array" error message.
On some variations I have tried, I get a "Ony user-defined types defined in a pubic object module can be coerced to or from a variant or passed to late-bound functions."
From the above, I surmise I must somehow define a procedure object or something, but admit its beyond my limited knowledge to attempt that task.
Anybody have some ideas about how I should do this thing?
BigInchworm-born in the trenches.
http://virtualpipeline.spaces.msn.com
RE: Passing a UDT to a procedure -"Expected array" error
Thanks for reading this, but no worries.  I got it.
'main code,
Call transform_xyz(transform)
'module
Public Sub transform_xyz(ByRef transform As transforms)
  'body
End Sub
When your;
  'body
End Sub
is in a Module your code is fine; when it is in a Form use;
Friend Sub transform_xyz(ByRef transform As transforms)
  'body
End Sub
vb6 assumed
regards Hugh
Those error messages sounded worse than they turned out to be.
"Friend", Interesting; I'll try that.
Thanks.
