pump selection
pump selection
pump selection
hello everyone, I have a general question, i need a pump that would be cheap, and be able to push a relatively small amount of fluid effiecently for short amounts of time. I know there is mutiple types of pumps that can be purchased. Any suggestions on which ones would be the best for my application? Thanks
RE: pump selection
What fluid?
How small or great a flow?
What pressures?
What temperatures?
What purpose, general mechanical use, food process, oil gas, chemical, potable water supply?
Might as well ask how long too?
BigInchworm-born in the trenches.
http://virtualpipeline.spaces.msn.com
RE: pump selection
As Biginch ask: your application?  Just what is your application?
RE: pump selection
sorry for being vauge,temp 25 degrees C, viscousity close to water, very low amounts because this is a model of a bigger system, the model hasnt fully been design yet but i think were talking less then a gallon flow through .5inch pipes. I plan on doing a modified bernioulis analasis in order to find out what pump power will be needed to generate the flow through the system, but from the looks at it were talking about pushing fluid a couple of feet horizontaly and a foot vertically
RE: pump selection
i forgot pressure, yeah im not looking at any exterme pressures, just enough the start of the system to power the fluid the way through the system. nothing crazy
RE: pump selection
There are a lot of good metering pumps on the market such as LMI
RE: pump selection
If you don't need much more than 12" WC, how about a big pipe/tank at elevation.
You fill it up when you need to "pump" and let gravity do the work.
Or, am I over simplifying this?
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: pump selection
for that i would to to constantly be filling the tank to generate enough head to power the fluid through the system, Thats my back up plan, however im just trying to get some input to pumping systems so i can weigh the pros and cons
RE: pump selection
looks like a diaphram pump for lab use. Contact your local lab supplier.
Best regards
Morten
RE: pump selection
philgrates,
Use a hose?
Or, you can use the level controller that a toilet tank uses (the float thingy). I believe Fisher used to make one.
Albert Einstein
