Circular Repeat to make cog
I've been using the circular repeat function to design a cog. I create one tooth in 2d sketch, repeat that, then join all of the teeth using the coincident constraint. Depending on the amount of teeth, this could take a while. The finished product ends up being off center. Is there a more efficient way to do this?
