V14 drafting help
V14 drafting help
I have a surface that i need to make flat in the drafting stage. Imagine a piece of paper that has a crease in it resulting in a 20 degree angle. In the drafting stage I need to make that piece flat again t show actual size. is this possible, because I can not seem to figure it out.
RE: V14 drafting help
If you have DL1 license, then in GSD you can unbend ruled surfaces, then project the result in a 2d view.
for more advanced surfaces composite design is required.
I've been told DL1 license in R17 can do more than ruled surfaces... did not test that yet.
Assuming one of your surfaces is planar:
In your CATPart, you will need to find the mold line (the intersection line between the two surfaces. You will then need to rotate the edge curves around that mold line onto the plane of the planar surface.
If your surface actually has some thickness (i.e. a sheetmetal part), you will need to find the neutral surface of the part first. Then find the mold line of the neutral surface, and flatten the neutral surface around this. The Neutral Surface for thin aluminum parts (i.e. less than .1 in thick) is usually around 43% from the outer surface. There are other values and formulas that can be used to determine the neutral surface.
