Custom Properties
Custom Properties
Custom Properties
In our title blocks, we have a block for "sheets".
Currently we use $PRP:"SW-Current Sheet" OF $PRP:"SW-Total Sheets"
On our sheetmetal drawings, on the last sheet we place a flat pattern that we use to create a DXF. We even label the last sheet "DXF". We really don't want SolidWorks to count the DXF sheet as one of the total sheets.
My questions is: Is there a way of subracting a sheet named "DXF" from the statement $PRP:"SW-Current Sheet" OF $PRP:"SW-Total Sheets"?
RE: Custom Properties
Not that I know of.
Could you just not use the total number of sheets function? Is it really a can't-live-without item?
or ...
Create a "NumberOfSheets" property in the drawing and link to that instead of the "SW-Total Sheets". Obviously you'll need to manually set/change the property.
cheers
Can you make it a separate file and add it to the Design Binder?
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
We use a separate file for flat layouts that will get DXFed for programming. The file gets the same name as the drawing except it gets a "NC" suffix.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP5.0 on WinXP SP2
SolidWorks 2007 SP2.0 on WinXP SP2
Are you using a PDM system?  Keeping track of multiple drawings for same part should be no problem then.
I have worked at places where it was necessary to keep mltiple drawings for parts (usually for in-process inspection).
Do you really need to keep a sheet for the DXF?  We simply create a temporary drawing of the flat pattern, save as DXF, then delete that drawing.  We just keep the DXF.  That only takes every bit of 2 minutes, so it's not a hassle.
SW07 SP2.0
Flores
I wanted the exact same thing, spoke with our VAR and they had no solutions other than a macro to create a seperate drawing just for the dxf. I also submitted an enhancement request to SW, maybe if more of us did that it might be a future option.
SW 2007 SP 2
Dell Inc. Precision WorkStation 670
2048 Megabytes Installed Memory
NVIDIA Quadro FX 1400
Windows XP PRO SP 2
