Hi all
Hi all
Is there a way to take an existing half circle that has been revolved 180 deg. and flatten it? I know i can flatten sheet metal, but can iregular shapes be flattened? Thanks in advance
RE: Hi all
sorry about the thread topic. i put the wrong text in that field. :)
RE: Hi all
I don't think you'll find an accurate way to flatten that within SW, since you'll have all sorts of stretch issues to compute in something like that.  Might have to upgrade to a more complex sheet-metal module to do something like that with greater accuracy.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
RE: Hi all
In most instances, if you can create it in sheetmetal you can flatten it. Not always, though. As for the half-circle, check out this thread and see if it helps you:
thread559-173297
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
RE: Hi all
thanks for the input, i'll check it out.
RE: Hi all
Mitsu50 ... If what you have is a hemi-spherical (bowl) shape, then you will not be able to flatten it.
cheers
RE: Hi all
I didnt think so, now its confirmed....
