FIRE PUMP MAIN SWITCH BOARD
I have to connect a 150hp fire pump from the utillity transformer.(150ft).
The MSB,(and feeder) should be dimensioned at LRA(LOCKED ROTOR AMPERAGE)or at 1.25 FLA?
I Now that i need only a disconnect and a overcurrent device in this circuit.(NEC)
Can i use only a unfussed disconnect in Fire Pump room, and a CB at the MSB(for the overcurrent(shortcircuit) purposses)?
RE: FIRE PUMP MAIN SWITCH BOARD
If you have a question regarding an intepretation of a specific code requirement, give us a specific question and code reference and you'll likely get a quick answer.
