Short command for counting blocks
Does anyone know what is the short command for counting blocks in a drawing? We are using AutoCad LT 2002. Thanks in advance.
RE: Short command for counting blocks
counter question: Do You know a long command for AC LT?
Lothar
ADT 2004
ACAD 2002
"Everybody is ignorant, only on different subjects." — Will Rogers
the problem is the LT-version. You can count blocks only with lisp, but it don't run on LT, except You have the LT-Extender...
http://ww
Lothar
ADT 2004
ACAD 2002
(defun C:COUNT ( / blocks ss)
(princ "\nPress <CR> to select entire drawing or,")
(cond
( (not (setq ss (cond ((ssget))
(t (ssget "_x" '((0 . "INSERT")))))))
(princ "\nNo objects selected."))
(t (princ "\nCounting block insertions...")
( (lambda (i)
(repeat i (count_block (ssname ss (setq i (1- i))))))
(sslength ss))
(cond
( (not blocks)
(princ "\nNo block insertions found."))
(t (table-print blocks "Block" "Count" "-" 8 "." nil 'itoa)))))
(princ)
(defun table-print (alist title1 title2 headsub coltab padchr
car-form cdr-form / maxlen maxline padstr )
(setq car-form (cond (car-form) (t '(lambda (x) x)))
cdr-form (cond (cdr-form) (t '(lambda (x) x))))
(setq maxlen
(mapcar
'(lambda (pair)
(cons (strlen (car pair))
(strlen (cdr pair))))
(setq alist
(mapcar
'(lambda (pair)
(cons (apply car-form (list (car pair)))
(apply cdr-form (list (cdr pair)))))
alist ))))
(setq maxlen (+ -2 (apply 'max (mapcar 'car maxlen))
(apply 'max (mapcar 'cdr maxlen)))
maxline (+ maxlen coltab)
padstr (count_repl padchr 70))
(cprinc-init)
(cprinc (strcat title1 " "
(ctab (cons title1 title2)
maxline
(count_repl " " 70))
" " title2))
(cprinc (count_repl headsub (+ maxline 2)))
(mapcar
'(lambda (pair)
(cprinc (strcat (car pair) " "
(ctab pair maxline padstr) " "
(cdr pair))))
alist )
(defun count_repl (chr len / res)
(apply 'strcat (repeat len (setq res (cons chr res))))
(defun ctab (pair max padstr)
(substr padstr 1 (- max (strlen (car pair) (cdr pair))))
(defun cdr++ (key alist)
( (lambda (x)
(cond (x (subst (cons (car x) (1+ (cdr x))) x alist))
(t (cons (cons key 1) alist))))
(assoc key alist))
(defun get (k l) (cdr (assoc k l)))
(defun entgetf (k e)
( (lambda (l)
(mapcar '(lambda (x) (cdr (assoc x l))) k))
(entget e))
(defun count_block (ename)
(apply
'(lambda (etype name)
(cond
( (and (eq "INSERT" etype)
(or (assoc name blocks)
(zerop (logand 45 (get 70 (tblsearch "block" name)))))
(setq blocks (cdr++ name blocks))))) nil)
(entgetf '(0 2) ename))
(defun cprinc-init ()
(setq *console-lines* (cond (*console-lines*) (t 25))
*cprinc-msg* (cond (*cprinc-msg*) (t "--- Press any key ---"))
*cprinc-rubout*
(cond ( (or textpage *clear-screen*) "")
(t (strcat "\r" (count_repl " " (strlen *cprinc-msg*)) "\r")))
*cprinc-line* -1)
(cond (textpage (textpage))
(*clear-screen* (*clear-screen*))
(t (textscr) (terpri)))
(defun cprinc-page ()
(princ *cprinc-msg*)
(grread)
(t (textscr)))
(princ *cprinc-rubout*)
(setq *cprinc-line* 0)
(defun cprinc (s)
(cond ( *cpage-disable*)
( (not *cprinc-line*)
(cprinc-init))
( (eq (setq *cprinc-line* (1+ *cprinc-line*))
(1- *console-lines*))
(cprinc-page)))
(write-line s)
; ############################ eof COUNT.LSP ################################
(princ "\nC:COUNT loaded. Start command with COUNT. ")
(princ)
</PRE>
