Dumb Question
Dumb Question
Dumb Question
Is there a replacement for the CR2032 Battery for our height Gauges that can be used?  Can't get any CR2032's.
RE: Dumb Question
I suppose you could use any 3v lithium cell that was close right. Is this a a logistics problem? Chances are if you have access to the internet you should find about everything, 2032 - very common size. You could find a calculator or led eychain, and rip one out. Anyways, I would direct you to try the battry engineering forum if you are looking for a permanent replacment type. http://www.eng-tips.com/threadminder.cfm?pid=658 Good luck!
RE: Dumb Question
I just bought one for my computer at Best Buys.
RE: Dumb Question
I buy them at the local drug store camera department! They are used in lots and lots of electronic systems. What is the problem of your not being able to find them? Did a wholesale supplier stop carrying them? If so, you may just need to go retail. Nobody has stopped making them for sure.
JRaef.com
"Engineers like to solve problems.  If there are no problems handily available, they will create their own problems."   Scott Adams
For the best use of Eng-Tips, please click here -> FAQ731-376
RE: Dumb Question
CR2032 is alive and well in the UK - we use quite a few of them on a variety of items where they serve as memory backup batteries. Just typing cr2032 in to Google brought up a huge number of hits from retail and commercial suppliers.
  Sometimes I only open my mouth to swap feet...
RE: Dumb Question
Try digi-Key there about $0.33 each they have a couple of brands
