Using Admin Mode
Using Admin Mode
Using Admin Mode
OK, I'm using the Admin mode and I'm trying to define drafting standards but seem to have a problem. I cannot find the 'setting' for which I can get a dimensions value centered with it's dimension line (gone through the help docs). It's always above the dim line :(
I do have it set to ANSI but I wonder if our current .xml file used for German prints (ISO) is interferring? If I open a drawing and change the standards file, I thought I would get an active update icon.
Happy Holidays!
RE: Using Admin Mode
Changing the standards on an already existing drawing does not always re-format the existing stuff.  Try re-creating the drawing and see if it is working, then you can worry about changing an existing drawing.
