Mechanical Engineering or Engineering Technology??
I am 26 years old, have a wife and two children, am a sophomore in college, and faced with a desicion to make.
First of all, allow me to explain my goals in life:
> I want to be a design engineer. I want to be a creator.
> I want to make good money doing so.
> I do not want to be limited in any way when it comes to my previous goals.
> Math and physics are my strong subjects; I do not want to be in a lab problem solving someone elses designs.
> I have a passion for the theoretical side of engineering. Basically, I enjoy mathematics and creating things.
Situation:
I am an Engineering Technology major (Mechanical concentration)(Bachelor of Applied Science). I have taken 6 Engineering Technology courses in college along with many standard courses such as English, Communication, History, and Calculus. I am evaluating the feasibilty of changing my major to Mechanical Engineering (Bachelor of Science in Engineering). If I change majors, none of the Engineering Technology courses I have taken will count towards my new major.
Questions:
1) Even if I am a very motivated individual, will the engineering technology degree limit me in life at all?
2) Even if I have to spend an extra year in school (along with other added hardships), is the Mechanical engieering degree going to be worth it compared to engineering technology degree?
Thank you for your time.
Brian
Situation:
Questions:
Brian
RE: Mechanical Engineering or Engineering Technology??
In my opinion yes it COULD limit you. My experience is that it could limit you in the following two major ways. A small percentage of companies will not hire MET's. Second the ME curriculum would be better if you want to get an MS later.
2. Hard to measure the comment "worth it". Do you mean monetarily? Maybe... Maybe not. I have an MET degree and have been very successful in my career; I have 16 years experience and am employed by a company that pays me on the upper end of what an ME with my years of experience typically makes according to Design News and Salary.com surveys.
You state that you really like math. If this is true you should like the ME degree better. Do you have the time, money, and inclination to back up and go for the ME?
Others will have other opinions and experiences
By the way, I appreciate your comments.
Brian
You are young enough that you will probably see this transition.
To me, the big advantage of the BSME is that it makes you a mechanical scientist...the buck stops with you. For example, if I'm delving into new scientific areas involved in my design, I can pick up virtually any book on the subject and understand it, no matter how much higher mathematics and advanced physical principals are presented. That's the principal reason you need all that math. You won't really use much, if any, calculus on the job, but knowing it allows you to fully understand how advanced mechanical principles work and why.
You are expected to be able to handle any mechanical, fluid, or thermodynamic situation that you come across, or be able to quickly research the problem and formulate a solution. In these situations an MET is very limited.
Don
Kansas City
For instance, here in Louisiana, the law says that to be licensed as a PE, you must be either an engineering intern, meet the requirements thereof, or be already licensed in another state whose requirements don't conflict with ours. To meet the requirements for intern certification with an engineering technology degree, you must get a master's in that field at a university which also has an ABET certified undergraduate program in the same discipline. Getting a PE license from another state that doesn't have the same requirements will not allow you to gain a license here. So, spending the time to get the BSME would be worth it because it allows you to pursue licensure much more easily. In the past, experience without an engineering degree was considered to be a valid qualification, but those doors are quickly closing in favor of a more rigorous and verifiable level of training and education.
This might be of importance to you because you said you'd like to do design engineering. If you want to work for a company doing design, the PE license is not necessarily essential because there will likely be one on staff who can stamp your designs, but without the PE license, you'll never attain that position. If you are interested in striking out on your own, it is almost essential. Granted, you could always hire a PE to work for you, but that's not as fun.
If you want to attain professional licensure as an engineer and all of the benefits and responsibilities that come with it, by all means, get the BSME.
Why don't you talk to your professors, and alumni of your program to find out what they are doing. That is truly the only way to know.
Oh and by the way, most of product design is "designed" by an industrial designer (ie artist) and you the engineer are expected to take their "design" and make it physically work.
Good Luck.
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
Of course I've met PhDMEs who couldn't design their way out of a cardboard box but their baliwick is more into science and theory.
If you want to make sound design decisions you have to possess quantititave skills which the MET degree does not provide.
As for practical knowledge, it's understood that the successful BSME newgrad must rapidly learn many things that were overlooked in his degree program.
To be honest with you, unless you're a genius an engineering degree can stifle your creativity because it so heavy on the analytics (again this only within my experience). I'm sure there are incompetent BSME's and crackjack BSMETs out there! It's just that most companies hire only BSMEs (or BMEs) because they know the education is more rigorous, opens doors for graduate study, and make someone more likely to take on an analytical and/or research role.
Tunalover
So yes, I would say the technology degree CAN limit your possiblities, especially if you desire to be a design engineer. However, that is not to say your goals cannot be realized with a technology degree. The technology degree gives you many useful skills, it will simply limit you in some companies.
Wes C.
Tunalover
Wes C.
Regarding the comment that "forsee the US requiring all Engineering functions being done by a PE" .... not from where I see the politically correct US heading!! Everyone is an Engineer (ie) Sanitation Engineer, (Garbage Man). Maybe they will in the Civil world but try looking at other industries.
Also the comment about "major" companies not employing MET's? Not from my experience. Largest Defense Contractor in the US employed me for three years with my MET degree.
Just my 2-cents worth.
"You can observe a lot just by watching"
Yogi Berra
The engineers job is to solve problems. Then that changes into how to solve it for a dollar less. What training, other than "hard knocks" do you think will better prepare you to solve problems. Knowledge is one think that cannot be taken away from us.
My quote would be " You shall above all things be glad and young" e.e. cummings
Enjoy the day.
Mecoman
A "real" engineering degree would have been better.
Where I went to school nights the difference was Calculus 3/4 and DIfferential equations courses. In the mid 80s my school (Lowell tech/ UMass Lowell Massachusetts) would transfer most, if not all of my machine design, strength of materials, etc credits towards a "day" degree.
Some employers did indeed turn up their noses at my BSMET (cum laude). At least 2 that hired me said they admired my diligence working and going to school. They sort of created positions to get me the pay I was asking. In my present job my experience (rotating machines, Solidworks, self taught FEA, experience with project management and DFMfg and DFAssembly ((making parts)) got me hired as a contractor. My performance and attitude turned that into a permananent position in a few months.
BS MET, with a PE is the best way to go. You will have the best of both world's.
Actually a technology degree is not a sufficient qualification for a professional engineer, for at least some jurisdictions. At the very least you may be required to take extra exams.
Cheers
Greg Locock
Please list the State that will not license as a Professional Engineer after taking the PE Exam if your B.S. Degree is in Mechanical Engineering Technology
Haven't we all!! "Engineers" with strings of qualifications who couldn't design a dogs kennel, much less erect it!
"Personally I wouldn't want a Physicians Assistant doing surgery on me"
Personally I'd want someone with a good track record of sucessful surgery not someone who had read the book and passed the exam.
"Now if only the states would mandate that all engineers be licensed and degreed, then we would at least have competency-by-regulation and licensure!"
Well they'd all have degrees and licenses, but would they be good engineers?
By the way, what qualifications did Brunel have?
As for how industry here treats them, there's little difference at the production-design level. There is a greater difference when it comes to R&D, where Engineers (licensed or not) are typically favored. There also tends to be a preference or greater flexibility in assigning Engineers to the more challenging projects. The assumption and historical norms put the Engineers as more capable in developing the abstract than EngTechs. I've found this to often be the case with the EngTechs that I've worked with, though I've also worked with a number of them who were far ahead of the majority of Engineers. Financially, I've seen Engineers get better assignments, postings and promotionsl, with the added pay that follows.
On the other hand, most of the EngTechs were under a lot less stress than the Engineers.
Regardless of which way you go, it's what YOU do with your education and training that will determine your prospects. Good luck!
Jim Sykes, P.Eng, GDTP-S
Profile Services
CAD-Documentation-GD&T-Product Development
www.profileservices.ca
Without a shred of doubt, I've decided to go with the BSME. I'm signed up to take ME classes for next semester.
Thank you!
Brian
To make sure you get into the type of work you want to do, you may want to look into intern, or summer jobs that give you the experience on paper (resume) that will help you standout once you graduate with the herd.
You cannot get a license solely with a BSMET. You also cannot go to another state that allows it and bring that license here and use it to become licensed.
New licenses for BSMETs without accompanying Master's degrees will not be issued under current law.
Louisiana Revised Statutes
LRS 37:681 through LRS 37-703
I wish you the best. As others have said, don't lose sight of the art of engineering while you're learning the more rigorous science of engineering and you'll do well. I'm also in with the camp that can't stress enough the importance of interning with a company. An engineering curriculum is only the bare minimum required to be an engineer. The things you learn on the job are just as, if not more, important. Basically, the piece of paper proves a bare minimum of ability. The experience you bring to an employer along with it is an assurance that you're not stuck in the ivory tower of academia and can perform in the real world. Don't fall into the trap of trying to get the degree quicker by sacrificing the internship.
Thank the Lord that the Wright Brothers were BSMEs.
Disclaimer
I'm writing this reponse under the assumption you were being sarcastic - if this is not the case then please disregard.
End Disclaimer
While I completely understand and agree with your implied point, it does nothing to answer the question the OP asked.
Yes, it's possible to get your dream job and be very good at it with an engineering technology degree, or no degree at all. This does not mean, however, that the opportunities presented to a person with this degree will be equal to those of a person with a BSME. I'm not by any means trying to say that a BSME is a be-all / end-all, far from it. I am saying, speaking from experience, that a large number of companies require a BSME when looking to hire engineering personnel.
As for the internship, I have been Co-op'ing for a year now. At this rate I will have 3 years experience when I graduate.
I understand what you mean about creative skills being stifled by an engineering program. The way I see it is there are alot of ways to solve problems (some better than others). I could be mistaken, but isn't it our job (as design engineers) to devise the best solutions to problems? In doing so, won't we be creatively thinking to solve these problems? I realize there are other functions of engieering, but I was under the impression that a design engineers primary function is to design. Doesn't the concept of designing and creating go hand-in-hand? For what it's worth, these are the observations/assumptions I've made. If I'm wrong, let me know. I also understand that things vary from place to place.
Thanks for all your comments.
Brian
Absolutely. As long as you remember that the word "best" is a completely useless word that will never define the solution to a problem, you'll at least be a step ahead.
Invariably, if you design low-cost and utilitarian, the sales department will want sleek and more expensive. If you design elegant and clean, marketing will demand another feature that will blemish your original lines. If you design strong and durable for long life, management will ask you to back it down a notch to cut down the costs (and in my cynical mind, move more product).
In the projects I've worked on, the design that went to market was never the "best" one in anyone's mind. Everyone involved had something they were forced to compromise on and thought could have been done "better".
Here's a quote right off the NCEES website:
"At the 2006 Annual Business Meeting of the National Council of Examiners for Engineering and Surveying (NCEES), delegates voted to modify the NCEES Model Law requirements for licensure to require additional education for engineering licensure.
The approved language states that an engineer intern with a bachelor's degree must have an additional 30 credits of acceptable upper-level undergraduate or graduate-level coursework from approved providers in order to be admitted to the Principles and Practice of Engineering (PE) examination.
NCEES committees have been studying this issue for more than five years, first through the Engineering Licensure Qualifications Task Force (ELQTF) and then through the Licensure Qualifications Oversight Group (LQOG). ELQTF, which was made up of representatives from NCEES, engineering professional societies, government, industry, and education, was established in 2001 to evaluate the U.S. licensure system. The task force concluded in 2003 that additional education would be necessary in the future to prepare students for engineering practice at the professional level."
Bottom-line:
Even the BSMEs will need ten more graduate and/or upper-classman three-semester-hour engineering courses to qualify to take the PE. Anyone else beleive the MET will fit into this new mold?
Tunalover
If you want to work as an engineer, you need a PE. To get a PE, it is prudent you have a engineering degree (not a technology degree).
If you want to work as a technologist, most firms will allow you even though you have an engineering degree.
If you want to work as an engineer, most firms will probably require you to have an engineering degree.
Depends on what you want now, soon and later, and what you can afford.
It is not an easy choice. Some posters here are pro engineer, some are pro technologist/designer. Some feel they wasted their effort getting their engineer degrees. Some feel they should have gotten the engineering degree.
It all comes down to what you want/need.
Talk it over with some people you know in your real life (not just on line), including your family.
Good luck.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
htt
Kansas, Iowa, Missouri, South Carolina, Florida to name a few. Follow the link above and you will have the complete list. It's not that these states will not allow licensure after taking the PE exam, they will not allow technology graduates to even take the exam.
Thank you for trying to reply to the question..Please list the State that will not license as a Professional Engineer after taking the PE Exam if your B.S. Degree is in Mechanical Engineering Technology
jpankask (Mechanical)
Yes!!!Now: I love this part: ABETaccredited 4-year engineering technology program if your statutes allow for such. "Purdue University School of Engineering Technology dose have an ABETaccredited 4-year engineering technology program".
Note In the NCEES 2005 Licensing Boards Survey what happen to the State of Indiana..
Also.. Note: Please check the State of Texas: 12 years of engineering experence now you can take the P.E.. Exam.
You are now armed with a lot of information. Only you know your goals, dreams and how you want to impact your community. We wish you the best of luck.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2007 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
Are you quoting yourself?
HaZakated-
I beg to differ with Heckler. As a design engineer I do calculations frequently and many of my decisions are based on quantitative data (hand calculations and FEA). Without a quantititative education emphasizing the sciences (e.g. physic) then I would be just "winging it" which is unacceptable in some industries.
Anytime a design failure involves human lives, expensive equipment, and mission success or failure you can't "wing it." I suppose there are some industries where you can "wing it" but I've never seen a project that didn't benefit from an individual possessing common sense, pragmatism, and quantitative skills.
I've had to step in and fix situations where designers/techs were given free rein to conduct a design without an engineer's involvement.
Tunalover
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
o
_`\(,_
(_)/ (_)
I have both degrees - one in MET and the other a BSME. I got my technology degree first (4 year degree) and then approximately 3 years later I got my ME.
Why?
1. I found my geographical locations for employment limited to certain areas. If I wanted to live in a certain area this was going to be a real problem.
2. The path to Professional licensing was longer (in Texas it is now 8 years vs. 4 for a BSME- it was 6 years)
3. At work, I found that my assignments were the grunt work of the ME's. Recognition was there, but the more important assignments were typically given to the BSME's.
4. ME's made more starting out although the gap closed after several years.
5. Lastly, I got tired of explaining that my MET degree was a true 4 year degree and not an associate degree. Some employers were trying to hire us at $18,000 (when the average starting salary was $29 to $30k).
6. Some employers didn't even know such a degree existed -that made job interviews start on the wrong foot.
Lastly, I have found in my 16 years of employed life - everything I have done to better my education has in fact bettered my life.
I used to tell interns that were asking the question about which path to follow:
You will most likely be able to do 80% of the same work as a full bird BSME, but you will have to explain it to every employer who doesn't know/understand what your degree is.
My last job would have been a real stretch with a MET degree due to the math and the design calculations - no one was there to teach me. However, I have hired MET knowing what they "are" and trained them to do "engineering" work.
My recommendation - get the BSME. You will not regret it.
roadapple
Great answer, examples and all. Star for you......
1) Earn BSME while working Co-op jobs/job.
2) Earn Masters of Science.
3) Earn P.E.
I think I'm starting to take shape...lol. I WILL succeed!
Thank you for your comments. Everyone has been very informative.
Brian
