Chlorine Dioxide Vs Bleach
At my current plant we treat our cooling tower basins with chlorine dioxide. During the shoulder months when the plant isn't being dispathced we still feed the clorine dioxide once a day untill we reach a level of 600 ORP. Unfortunetly when the plant is down and we have no need for make-up water, the HCL in the chlorine dioxide drives the tower pH down below our operating range. This causes us to dump a bag of soda ash into the basins to bring the pH back up. To get away from dumping the soda ash in the basin I was thinking of setting up the chlorine dioxide units to just feed Bleach. Will I get the same oxidizing potential as I do with the Chlorine dioxide? What risk do I run by continuing to treat the basins with a bag of soda ash? we are currently using about a bag per week per basin...
thanks folks
thanks folks
RE: Chlorine Dioxide Vs Bleach
The risk that you take by adding soda ash is to increase the dissolved salt (TDS) concentration in the cooling tower. AS TDS increase, the water is more corrosive. This TDS is easily controlled by increasing the cooling tower blowdown.
Mark Hutton
