30" Wafer Check needed Urgently!!!
Hello everyone...
I am trying to locate a Wafer Check valve URGENTLY with the folowing specs:
Class: 125
Body: Cast Iron
Seat: Buna N
Flapper Plates: 316 Stainless Steel
Spring/Pins: Monel
Any idea where I can locate this out of stock?
Abdool
RE: 30" Wafer Check needed Urgently!!!
Try a Google search on | surplus valves |.
Also, even though it's oriented toward finding job shops for custom work, I have had modest success finding odd stuff through
http://www.mfgquote.com/
Mike Halloran
Pembroke Pines, FL, USA
Thank you.
Abdool
Check www.technovalve.com although I'm not sure about the "stock" part!
