ADJUSTING THE PERSPECTIVE VIEW
is there a way to adjust the angle of the "perspective view"... in other words if I wanted to show an image where the perspective is greatly exaggerated is there a way to adjust the angle of perspective?
I checked the options but didn't really see anything......
thanks
John
RE: ADJUSTING THE PERSPECTIVE VIEW
after a little more searching around, I found it.... view>modify>perspective.
thanks.
Try using the camera--create a camera and you can get excellent results in dialing in whatever you need--as well as focal length (can blur areas in foreground/background).
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
