output coordinate system
I'm exporting to .stl; in the export options there is the option "output coordinate system" which has the single option of "default" -what are my options?
RE: output coordinate system
In this case, none.
If you create coordinate systems in your model, you can pick one to use for your output.  This is often handy for orienting output to match you machines.
