List dimension names and their values
I would like to create a list of dimension names, their values and associated tolerances for all dimensions in a detail drawing.
This list will be used to document output from a CMM (Coordinate Measuring Machine).
Is this possible without being proficient in the SolidWorks API?
Thank You
JoeM
SolidWorks 2006 SP 3.1
Thank You
JoeM
RE: List dimension names and their values
CODE
Dim swDoc As SldWorks.ModelDoc2
Dim swDwg As SldWorks.DrawingDoc
Dim swView As SldWorks.View
Dim swDispDim As SldWorks.DisplayDimension
Dim swDim As SldWorks.Dimension
Dim swTol As SldWorks.DimensionTolerance
Dim xlApp As Excel.Application
Dim xlSheet As Excel.Worksheet
Dim xlBooks As Excel.Workbooks
Dim CurRow As Long
Const STARTROW As Long = 3
Const DIMNAMECOL As Long = 2
Const DIMVALCOL As Long = 3
Const DIMTOLTYPECOL As Long = 4
Const DIMUPPERTOLVALCOL As Long = 5
Const DIMLOWERTOLVALCOL As Long = 6
Const DIMTOLFITCLASSCOL As Long = 7
Const TOLSCALEFACTOR As Double = 1000
Sub ExportDims()
Dim NumTolVals As Integer
Dim TolIsFit As Boolean
Set swApp = Application.SldWorks
Set swDoc = swApp.ActiveDoc
If swDoc.GetType <> swDocDRAWING Then
MsgBox "This macro only works for drawing files."
Exit Sub
End If
Set swDwg = swDoc
Set xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
Set xlBooks = xlApp.Workbooks
xlBooks.Add
Set xlSheet = xlApp.ActiveSheet
CurRow = STARTROW
xlSheet.Cells(CurRow, DIMNAMECOL).Value = "Dimension Name"
xlSheet.Cells(CurRow, DIMVALCOL).Value = "Nominal Value"
xlSheet.Cells(CurRow, DIMTOLTYPECOL).Value = "Tolerance Type"
xlSheet.Cells(CurRow, DIMUPPERTOLVALCOL).Value = "Upper Tol"
xlSheet.Cells(CurRow, DIMLOWERTOLVALCOL).Value = "Lower Tol"
xlSheet.Cells(CurRow, DIMTOLFITCLASSCOL).Value = "Fit Class (Hole/shaft)"
CurRow = CurRow + 1
Set swView = swDwg.GetFirstView
While Not (swView Is Nothing)
Set swDispDim = swView.GetFirstDisplayDimension5
While Not swDispDim Is Nothing
Set swDim = swDispDim.GetDimension
Set swTol = swDim.Tolerance
xlSheet.Cells(CurRow, DIMNAMECOL).Value = swDim.FullName
xlSheet.Cells(CurRow, DIMVALCOL).Value = swDim.Value
xlSheet.Cells(CurRow, DIMTOLTYPECOL).Value = GetTolTypeName(swTol, NumTolVals, TolIsFit)
If NumTolVals > 0 Then
xlSheet.Cells(CurRow, DIMUPPERTOLVALCOL).Value = swTol.GetMaxValue * TOLSCALEFACTOR
End If
If NumTolVals > 1 Then
xlSheet.Cells(CurRow, DIMLOWERTOLVALCOL).Value = swTol.GetMinValue * TOLSCALEFACTOR
End If
If TolIsFit Then xlSheet.Cells(CurRow, DIMTOLFITCLASSCOL).Value = swTol.GetHoleFitValue & "/" & swTol.GetShaftFitValue
Set swDispDim = swDispDim.GetNext5
CurRow = CurRow + 1
Wend
Set swView = swView.GetNextView
Wend
xlApp.Range("A:Z").EntireColumn.AutoFit
End Sub
Function GetTolTypeName(ByRef myTol As SldWorks.DimensionTolerance, ByRef NumVals As Integer, ByRef FitTol As Boolean) As String
Dim s As String
FitTol = False
Select Case myTol.Type
Case swTolNONE
s = "None"
NumVals = 0
Case swTolBASIC
s = "Basic"
NumVals = 0
Case swTolBILAT
s = "Bilateral"
NumVals = 2
Case swTolLIMIT
s = "Limit"
NumVals = 2
Case swTolSYMMETRIC
s = "Symmetric"
NumVals = 1
Case swTolMIN
s = "Minimum"
NumVals = 0
Case swTolMAX
s = "Maximum"
NumVals = 0
Case swTolMETRIC
s = "Metric"
NumVals = 2
Case swTolFIT
s = "Fit"
NumVals = 0
FitTol = True
Case swTolFITWITHTOL
s = "Fit With Tolerance"
NumVals = 2
FitTol = True
Case swTolFITTOLONLY
s = "Fit, Tolerance Only"
NumVals = 2
FitTol = False
Case swTolBLOCK
s = "Block"
NumVals = 2
FitTol = False
End Select
GetTolTypeName = s
End Function
Thank you for the fast response and code sample, I really appreciate it.
Joe
Although I have some programming experience, and quite a bit of solidworks experience I have zero experience with APIs('cept googles map API).
I tried building a marco with your code, but quickly get an error when you declare the excel app
"Dim xlApp As Excel.Application"
I am sure I am just doing something wrong.. thanks!
Compile error:
User-defined type not defined
You'll need to include a reference to the Excel object library. To do this, click Tools->References from the VBA editor. Scroll down in the list and check the box for "Microsoft Excel [version number] Object Library", then click OK. That should take care of the problem.
Enjoy, and good luck!
I now get an error on this line:
"assignment to constant not allowed".
not sure why that isnt working. i was thinking about just assinging swDim to a double or something, and then getting rid of "set" but since this is your code, and apparntly HAS been working- i figure I am doing something wrong.
thanks again :) !!
Dim swApp As SldWorks.SldWorks
through
you would get the error you described. swDim has to be declared as a SldWorks.Dimension. Otherwise, it looks in the libraries and finds that swDim is a constant defined in the swGeomType_e enum of the constant type library with a value of 12. Obviously, you can't change the value of a constant, much less assign it to an object.
So basically I chose the name of that variable poorly. If you copied all of the declarations at the top then they should take precedence over the constant in the library. However, SolidWorks/VBA don't always seem to get the order of precedence correct, so if you did copy the declarations and you're still getting the error, try replacing every instance of "swDim" with "mySwDim" or something similar.
