2005 Rolled sheetmetal
All,
I am trying to create a rolled sheetmetal part in SW2005. I am having difficulty getting this to work. I viewed thread559-83712 and have not found this to help much. I have started by drawing the bent profile first, then I did a Base-Flange on that sketck. That worked, but when I try and view the flat pattern it is still the formed shape. ANy help would be greatly appreciated.
RE: 2005 Rolled sheetmetal
h
I had no problem creating a part in the manner you described. Here's what I did:
Start a new sketch and draw an arc.
Create a base-flange, choosing material thickness and the length of the flange.
Create.
Select Flat-pattern...no worries.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Beyond that, it should have worked as btcoutermash stated.
Jeff Mirisola, CSWP
CAD Administrator
Sorry, but I have one other part with similar issues. Any Ideas?
http://
"I was forgeting about adding the thickness and using a single line in the sketch..." ?????
Please post image WITH Feature Manager tree included, or better still the actual file.
Jeff Mirisola, CSWP
CAD Administrator
Create a base-flange, choosing material thickness and the length of the flange."
I was trying to use a closed profile then extrude instead of using a single line as the profile, then in the base flange command adding the thickness.
Issue 2 is that the part I have is only a stp model. It was created in inventor, and SW does not do that good of a job with feature recognition. We are trying to recreate this part so we have a good SW part and print.
Would you like to see the stp??
I really do appreciate it.
http
after creating the base flange, you need to unfold the part, not flatten it. Next to the flatten button, on your sheetmetal toolbar, you should see two other buttons. One is 'Fold', the other 'Unfold'. Use these to creat your cut.
Jeff Mirisola, CSWP
CAD Administrator
Create the flat first using the supplied dimensions. Insert a sketched bend vertically at the center of the center of the part. However, the radius called out on the sheet is too large. The largest radius that I could get to work is 4.66 inches.
Jeff Mirisola, CSWP
CAD Administrator
Your post this morning at 9:51 actaully worked great for what I needed. If you'd like to take a look:
http
Off topic here, but I went to high school with an Eva Coutermash...not a common name.
Jeff Mirisola, CSWP
CAD Administrator
