2007 plotting trouble
Hi all,
Can't get the printer, Ricoh 1027 (B/W) to print yellow anything but grayish. Tried everything, but not the right thing. I believe I've had the same problem on R14 some years ago, but I can't remember the fix. All other colors print black.
Anyone had the same problem?
Dan320
Dan320
RE: 2007 plotting trouble
"Everybody is ignorant, only on different subjects." — Will Rogers
that maybe you have set the print to
monochrome which would print everything in
black or shades of grey. You have to
assign the pen colors and styles and widths
in some setup if 2007 is similar to the past
versions.
ACad still has some basic things not taken care of or made easy it seems.
Dan320
