Cannot SET Object! Run-time error '91' - Object not set
Help! My code was working fine yesterday, I'm not sure what happened.  I have an object swChildComp, declared as
Dim swChildComp                 As SldWorks.Component2
-- which works fine, because I can extract a part name from it
strModName = swChildComp.Name
--but when I try to set another object, declared as
Dim Part                        As Object
--then set like this:
Set Part = swChildComp.GetModelDoc
-- it remains as 'Nothing'
what gives?  Like I said, it was working before, then it broke.  The only (possible) significance I noticed is that when it was working, I had another macro still loaded in SW VBA.  I think it may have stopped working when I finally closed SW and unloaded the other macro. The 2 macros were destined to become one anyway, so I figured I could work around the issue by going ahead and merging the two.  So I did, but nothing changed.
What could be going on? Any ideas at all?
RE: Cannot SET Object! Run-time error '91' - Object not set
Why are you delcaring Part as Object rather than SldWorks.ModelDoc2?  That could help.  Also, according to API help, if the component is either suppressed or lightweight then the GetModelDoc call will return Null.
handleman,
I took your advice, and it worked!  I also moved that line of code to follow
If (False = swChildComp.IsSuppressed) And (False = swChildComp.ExcludeFromBOM) Then
to check for suppressed components.  *DOH!*
Thanks again handleman, The Tecumseh Group should put you on their salary!
He is ... trouble is their currency is little purple stars.
cheers
