Calculation of FIT or MTBF
Hello all,
from my customer I got the requirement for my system:
5 ppm at lifetime of 10.000 hours. How can I calculate the FIT and the MTBF out of this?
What is wrong in this calculation?
MTBF= 10.000h * 5 *10 exp -6  = 2 exp9 h
Fit= 1/MTBF = 0.00024
thanx
ALex
RE: Calculation of FIT or MTBF
you're mixing apples and soda pop.  It's completely unclear from your posting what the 5 ppm refers to.
If the "lifetime" is 10 hrs, then that's the MTBF as well, is it not?
TTFN
HI,
The requirement is that during lifetime of 10.000 h 5ppm of the ECU's are 'allowed' to go bad..
Is it now better defined?
Alex
There are various means to find out the MTBF.
Some time we conduct two types of test to find out the MTBF,. One is time terminated test and other is failure terminated test. The above problem can taken under time terminated test.
No. of test samples - 1 Million
Hrs tested - 10000 Hrs
Failures - 5
Failure time (t1, t2, t3, t4, & t5)
i.e first sample failed at t1, second sample failed at t2 etc.
MTBF = [10000 ( 1000000-5)+ (t1+t2+t3+t4+t5)]/1Million
Note: We normally use 10 to 50 samples
Accurate failure rate is a data-driven metric.  When do 50% of them actually fail?
Barring that, your specification, 5 ppm at 10 hrs, basically implies a 5/(10^6*10) or 0.5 failures per million hrs, which is an MTBF of 2,000,000 hrs
TTFN
Hello all,
Thanx for the replies...
@IRstuff: your using a linear distribution...isn't it? Should we not use a gaus-distribution?
Here is the possibility which came into my mind
(At the weekend after 5 beers..  smile)
barring this picture would be a gaus-curve...  smile
The mid of the curve will then represent the MTBF.
|         _
         MTBF
No I have to calculate the area under the curve and set it equal to my 5 ppm..
The formula would be something like:
Integral f(10.000 h) = 5 ppm
What do you think to this?
You can try, but you'll find that it's impossible to do that integral without both MTBF and the standard deviation.
Moreover, the concept of MTBF is a linear function, constant-number-of-failures per unit time
TTFN
