ADDING WEIGHT INTO A DESIGN TABLE??
CAN ANYBODY HELP?
HOW DO YOU ADD A CONFIGURATION SPECIFIC WEIGHT INTO A DESIGN TABLE? THERE ARE NO PARAMETERS TO DOUBLE CLICK ON TO GET IT TO GO INTO THE DESIGN TABLE. THANKS
RE: ADDING WEIGHT INTO A DESIGN TABLE??
It should automatically capture the variations between configs, which in this case would be the $PRP@Weight parameter.
Just a curiocity, why do you need to add "weight" properties into a design table? Design table is mainly for inputs. Are your configuration specific weight properties inputs to your design? Otherwise, you should consider using general tables.
Alex
I don't think that you can drive the mass of a part. You only can assign mass to a part.
Alex
