converting graphic file to autocad dwg/dxf
Do anyone know how to do this?
Thank you in advance.
Best regards,
ct
RE: converting graphic file to autocad dwg/dxf
Tip
I would attach the image in ACAD, and draw the vectors by myself. It's more exactly, if you need it.
Lothar
ADT 2004
ACAD 2002
Do a search on "raster to vector" and you should see some suggestions.
"Everybody is ignorant, only on different subjects." — Will Rogers
